Sound on my PC won't work properly
Hello all,
This forum has been amazingly helpful before so I thought I'd ask you people in the know.
Anyway I just had my pc built and everything but the audio seems to be working great. When I plug the speakers or my headset in the sound comes out fuzzy and doesn't work properly its stop start and you can't make out the sound what so ever.
It's not that I have anything muted or something daft like that and I went to Control Panel > System > Device Manager > Sound etc and it says nvidia high def audio x4 all enabled and installed.
Was wondering if you guys have any ideas in what might be wrong and ideas on what I could try to make it work. Thanks.
1 answer Last reply
More about sound work properly
  1. you may have hooked up the audio connections to the motherboard improperly.
Audio
