I think there may be cooling issue with my sp94. Please help with any suggestions/comments .
Am running a p2.8 on an IC7-G mobo. Case temp in both scenarios below ~ 30C
Previous setup: intel stock hsf with thermal pad
idle temp: 45C
under load (prime95 torture): 64/65C
Replaced today with: SP94, 92mm acoustifan with arctic silver 5.
idle temp: 45C - Exactly the same as my stock HSF
Under load (prime95 torture): 59C
I expected to see my cpu idle and load temps to be lower than the results show.
Please help with any suggestions you might have.
idle temp: 45C
