Archived from groups: microsoft.public.windowsxp.general (More info?)
Hi
My windows XP gateway machine ran into a problem where I cannot print. When
I tried to
locate/add the printer I got the message "Cannot add...print spooler not
running".
I browsed thru the msgs and I found that I could restart the spooler by
going thru
Admistrative Tools->Services->,, but the spooler would not start.
I even tried starting from cmd prompt
> net stop spooler
> net start spooler
and I get the message:
Cannot start print spooler System Error 23 (Cyclic Redundancy Check)
The printer is a Samsung ML-1210 laser printer connected directly to the PC.
Kishore <Kishore@discussions.microsoft.com> wrote on Thu, 15 Sep 2005:
>Hi
>I tried to
>running".
>going thru
>> net stop spooler
>> net start spooler
>Can someone please help?
Hi Kishore
Try reinstalling your printer driver, then the spooler service.
Hi Nightowl
Thanks for the tip..unfortunately that did not work.
One thing I noticed is that my system restore is not working either,
there are no backups from previous dates and my system restore
is set to be active.
thx,
Kishore
"Nightowl" wrote:
> Nightowl <owl@[127.0.0.1]> wrote on Fri, 16 Sep 2005:
> >Hi Kishore
> Oops, I meant to say: ". . . then starting the spooler service."
> Nightowl
