Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Win XP Installer Problem?
Archived from groups: microsoft.public.windowsxp.general (More info?)
I am having trouble installing Roxio Easymedia 7.5. Roxio support thinks a
problem within my Windows Installer is making the Roxio instalation routine
malfunction. They also cite as an indicator the fact that I can't use
Windows Automatic Update. Whenever I try to install an update received via
AU it fails. I have to go to WU web site and manually down load the patch
then install it. Does anyone have any ideas?
Sponsored Links
Hi it seems like you might have some problem with windows installer go to
microsoft updates site not windows update
http://update.microsoft.com/microsoftupdate/
and go though that and run the updates there and download everything and
restart the computer it should download a new windows installer 3.1 and then
you should be able to install the roxi easymedia 7.5 OK if this does not help
you then I will let you know what else to do ok thanks.
Reply back and let me know how it goes. Don''t forget to select yes if this
was helpful on my post. I always like helping out people with there problems.
Thanks
Matthew Senecal
Reply to Anonymous
Windows Installer 3.1 (v2) is available
http://support.microsoft.com/defau [...] -us;893803
Rock
MS MVP Windows - Shell/User
Reply to Rock
"Jim" <Jim@discussions.microsoft.com> wrote in message
news:D49D1AFB-300B-4FF3-91F7-E960A117E181@microsoft.com...
> routine
> via
Also, try the Installer Cleanup Utility:
Description of the Windows Installer CleanUp Utility
http://support.microsoft.com/defau [...] -us;290301
Don
Reply to Anonymous
There are 1202 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
