How to get wireless speakers and wired speakers to work together on pc
hi ive got a touch screen pc which is used as a jukebox, ive been using wired altec lansing speakers{3.5 jack} which worked fine ,ive recently bought a altec lansing wireless speaker {usb} it seems i can only use one or the other, is there anyway i can have both working at the same time,thanks
1 answer Last reply
More about wireless speakers wired speakers work
  1. USE adapters, 3.5 MM to RCA, then install a RCA Y cords. The Y cords will split the signal.
    You can get these Y cords or adapters at Radio Shack...
Wireless Speakers Touch-Screen Audio
