Archived from groups: microsoft.public.windowsxp.general (
More info?)
Oh never mind.. I found if I open them with paint and then resave them it
somehow converts them over to JPG.. Thanks So much for fixing it.. Joe
"Ramesh, MS-MVP" wrote:
> Did you select JPG, and click the "Repair associations" button ?
> >> Do you think I will have other issues with non JPG files ???
> Do you have the same problem viewing other file types?
> Ramesh, Microsoft MVP
> Windows XP Shell/User
http://windowsxp.mvps.org
> "cole098" <cole098@discussions.microsoft.com> wrote in message
> news:8EC71550-0D27-4EF5-BA0D-705838BB1CB4@microsoft.com...
> > Thanks so much you fixed it with the code I pasted in RUN. Do you think
> > I
> > will have other issues with non JPG files ??? Any other codes I can copy
> > and paste in the RUN line.. Thanks
> >> >> reset to defaulyt
> >> Try this from Start, Run:
> >> CMD /C ASSOC .jpg=jpegfile
> >> news:9E54CC74-12C9-449D-99D9-77D42735BDA5@microsoft.com...
> >> > Thanks for responding back.. Its for JPG files.. I tried the software
> >> > you
> >> > suggested to reset to defaulyt and it didnt work.. Any other ideas..
> >> > Thanks
> >> > fir the help. Joe
> >> >> For which filetype?
> >> >> Repair image file type associations in Windows XP:
http://windowsxp.mvps.org/imgassofix.htm
> >> >> news
3072A70-2B37-4F72-8275-E826828DFE14@microsoft.com...
> >> >> > Whenever I double click on a picture in my pics folder it refuses to
> >> >> > open
> >> >> > it
> >> >> > up to a bigger window that shows the pic enlarged. I also cant use
> >> >> > any
> >> >> > of
> >> >> > them as a picture for my desktop..
> >> >> > This is what the window that pops up states.....
> >> >> > " THIS FILE DOES NOT HAVE A PROGRAM ASSOCIATED WITH IT FOR
> >> >> > PERFORMING
> >> >> > THIS
> >> >> > ACTION. CREATE A ASSOCIATION IN THE FOLDER OPTIONS CONTROL PANEL."
> >> >> > Then
> >> >> > it shows the OK button to click on.
> >> >> > What can I do so I can view my photos like I use to???
