Help! 5.1 Sound Card
wjmexp
4
hello, ive recently bought a pair of 5.1 surround sound headset that comes with an amp and 4 colored jacks: green pink black and yellow. I know my sound card can support 5.1 audio but theres only a pink and green plugin on the front of my tower and green and blue on the back.
Should I buy a new sound card eventho it would only be for the plugs?
Is there any kind of way to add the black and yellow plugs missing?
what do you suggest?
thanks :) and sorry for de bad english.
green TRS 3.5mm stereo output, front channels
black TRS 3.5mm stereo output, rear channels
grey TRS 3.5mm stereo output, side channels
gold TRS 3.5mm dual output, center and subwoofer
blue TRS 3.5mm stereo input, line level
pink TS 3.5mm mono microphone input
http://en.wikipedia.org/wiki/Audio_and_video_connector
green is for the front speakers
black is for the rear speakers
gold is for the center and subwoofer
pink is for your microphone
i have no idea why your integrated soundcard, slot soundcard, or whatever it is that you have hooked up has the ports split between front and rear.
if that is the case then yes you might want to get a cheap $20 soundcard to throw in your pci slot if just for the connections.
