Nakamichi 582 sticking capstan motor
Hello, My Nakamichi 582 capstan motor doesn't always start rotating on power up, but a very light push on the capstan wheel and it's away. It is intermittent as though there is a "bald spot" when the armature stops at a certain position. Is it a new motor or will it respond to a squirt of switch cleaner ?
1 answer Last reply
More about nakamichi sticking capstan motor
  1. The capstan shaft must be removed and cleaned, lubed.
    The belts probably need replacing.
    DO NOT "shoot" cleaner into the machine.
High-End Audio Light Power Up Audio
