trahant
How do you take apart the bose 101 outdoor speaker? Mine just stopped working completley...not even a crackle. Tim
jacobboe89
176
yes the screws are located inside the grill . i have owned a pair of 101's and got into them at some point . bose used 1 ohm drivers in these and they had a resistor across the + and - at the driver connection inside to get a 4 ohm impedance . if that resistor is bad , i haven't a clue as to where you would get one or what value to try and replace it with , which if your drivers are blown , that may be the reason why
trahant
Thanks for the answer on my bose 101 outdoor speaker......it was helpful. Tim
