I have a problem known as Matt S. I have a Maxtor external hard drive which is not being detected by my Dell Laptop. I have the USB cable plugged into the docking station, and the laptop itself only has a USB2.
Have you tried plugging it directly into the Laptop? Is the drive Powered from the USB connection or a separate power supply? maybe the docking station USB port doesn't deliver enough power for some reason? Just a thought.
it doesn't seem to have a USB connection directly on the laptop. good idea as I tried that and that could certainly be the issue because I have no lights on the external hard drive.
Does the drive definitely work? I assume you've used it on another computer somewhere, so probably does I guess..
did it come with any drivers or utilities?
Also, a laptop with NO USB ports is very odd. even really slimline versions usually have at least one USB port. you sure it's not just hidden behind some little flap somewhere?
