Who Dunnit reel problem
G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Hi.
Do the reel have a own fuse or something?
If i try the reel in the testmenu it works. But i get switch error on
the reel when i turn on the game, and it doesnt work when i play.
I have check the cables.
Do the reel have a own fuse?
G
Guest
Guest
no
>If i try the reel in the testmenu it works. But i get >switch error on the reel when i turn on the game, and it >doesnt work when i play.
You identified your problem without even knowing about it.
Does the opto work on the reel in switch edges test? The reel may turn
in test mode, but if the switch (opto) is not working the reel will be
disabled in the software. Check the opto.
Kirb
