Toshiba problems
G
Guest
Guest
Hello,
my toshiba sattelite laptop's hard drive has gone out on me twice in a year, the first time it gave me warning, said a disk on the drive was failing, second it told me boot manager is missing,is this due to the common overheating problem with toshibas?
hdd's can fail from excessive use (insufficient ram), bumping/jaring/dropping, heat (yes but laptops - rare), excessive startup/shutdown (power saving too strict), etc - drives should last a good two years atleast - perhaps you just had back luck?
