G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Getting the above error message stating that the "Class not registered" oddly
enough while attempting to run iKernelUpdate.exe.
I originally received this error trying to uninstall an existing
application, then while attempting to install a newer version of the
application.
After a bit of research, I went to support.installshield.com and found
instructions on how to remove version 6 and run the update. Unfortunately,
the update gets the same error.
Anyone else run into this and find a solution? I'd hate to think that I've
got to re-install everything.
Any suggestions are appreciated!! Thanks in advance!!
application.
