Tom's Hardware > Forum > Systems > Dell > Sound record volume
Archived from groups: alt.sys.pc-clone.dell (More info?)
When I record to disk using MS Sound Recorder, the volume is very low
and there is a lot of background noise. It feels like something is
wrong with the input level.
The hardware setup is a cable from the headphone output of a player
to the line-in of the computer. When I select line-in to the
playback, the sound to the computer speakers sounds great, no noise or
distortion and good volume.
The software is MS Sound Recorder on XP Home. On "volume control" I
selected line-in and tried minimum, middle, and maximum volume
settings. I also tried maximum volume on the player.
What am I missing? Shouldn't this work?
Sponsored Links
Try "Line Out" instead of the headphone jack.
Reply to Anonymous
"kgold" <kgold@watson.ibm.com> wrote in message
news:40c46edd_2@news1.prserv.net...
In the Volume Control there are two panels. One for playback and one for
recording. Make sure you are changing the volume of the Recording Properties
one. Also, other channels (usually Aux In) can cause a lot of noise just by
being there. Try muting the Aux In channel too if you're not using it for
anything. Turn the headphone volume control up to about 90% of your output
device. You want to keep the volume high "upstream" and reduce (if it's too
loud) and the recording point, not vice versa.
Reply to Anonymous
Vince McGowan <SPAMvincemcg@nada.com> writes:
My player doesn't have a "line out", just a headphone jack.
I was assuming that:
1 - The headphone jack was roughly the same power as line in.
2 - Since the playback volume is OK, the problem is not with the input.
Are either of these conclusions wrong?
What about using the sound card mic input. Other than keeping the
input volume low so I don't blow something up, are there other
problems?
Reply to Anonymous
What is the name and model number of your computer?
Rocky
news:40c5be99_2@news1.prserv.net...
> problems?
Reply to Anonymous
Recent Dell 4600 with standard sound card.
"Rocket J. Squirrel" <rocky@bullwinkle.com> writes:
> Rocky
> > problems?
Reply to Anonymous
Your sound card has line out.
Rocky
news:40c620d7_2@news1.prserv.net...
> > Rocky
low
is
player
noise or
input.
> > > problems?
Reply to Anonymous
#1 - here I'm assuming the headphone jack has a volume level - have you
tried turning up the volume at the source? That would raise the signal
level going into your sound card. The Line Out level is independent of
the volume setting.
> problems?
Reply to Anonymous
But the signal source doesn't. OP needs a decent level for the Line In
jack of his sound card for recording.
Reply to Anonymous
Missed that part. Sorry for the misunderstanding.
Rocky
"Vince McGowan" <SPAMvincemcg@nada.com> wrote in message
news:gzuxc.18418$IQ2.9204282@news4.srv.hcvlny.cv.net...
Reply to Anonymous
No problemo
Reply to Anonymous
> the volume setting.
Yes, I've turned the player's volume all the way up.
When I select the computer "line-in" source to the playback, it sounds fine
through the computer speakers. Good volume, no noise, no distortion.
But when I select the same "line-in" to record, the volume is low and
noisy. The "oscilloscope" green line barely moves.
Reply to Anonymous
news:40c71242_4@news1.prserv.net...
Did you change the Line In's Volume in the RECORDING PROPERTIES? There's two
sets of sliders for every port (on two different screens). On for recording
and one for playback. Playback is the only one you see by default. You have
not set it correctly there OR you have your record source set to "What U
Hear" (in the recording volume applet) and it's slider is too low. It's one
of these two things. It HAS TO BE.
Reply to Anonymous
"Ricky W. Hunt" <rhunt22@hotmail.com> writes:
I have the RECORD volume at maximum and all other inputs muted.
I tried turning the headphone volume from middle to maximum. The
result was a sound which was still low and noisy, but also distorted.
However playback of this line-in still sounded fine.
My conclusion from that is that the volume into the computer line-in
is sufficient (because of the distortion and good playback), but
something after that is attenuating the input. The oscilloscope line
barely moves.
I agree. It should work.
BTW, what's the "recording volume applet" (sounds like Java) and "What
U Hear."
Reply to Anonymous
news:40c8644c_4@news1.prserv.net...
> barely moves.
What application are you using to record? Is the oscilloscope the one that
comes with the Soundblaster (Creative)?
> U Hear."
If you don't see these two things that what I'm betting when I said I
thought you might not have the record slider up. There's two completely
different set of sliders. One is for playback is the default one you usually
see. In Windows XP you can get to the second one by going to Control
Panel/Sound and Audio Devices. When that comes up go to the Audio tab. Click
on the button marked "Volume" under "Sound Playback" (the top box). When the
volume control comes up (which should be the same as the one of the taskbar)
click on Options/Properties. Here you choose with set of sliders to adjust.
Switch it from Playback to Recording. A completely new set of sliders will
pop up. Make sure the Line In on it is up and it's selected. You can only
select one at a time when in this menu which lets me know you probably
haven't been in because you can't "mute" any channels. The very last slider
is called "What U Hear" and is a special "input" (software) that records any
audio being produced by the computer (i.e. anything you hear coming out of
your speakers). There's not much call to use this unless for special
circumstances and many people's problems, especially when trying to
multitrack record is due to have this selected.
Reply to Anonymous
Ok. I only own an old dell P2 on a little home network. But I have
tried that "Sound recorder" of XP's to record my voice on my Athalon.
No one has mentioned this, or I missed it, so maybe this is it. You
need to change some recording settings.
You need to open up the sound recorder and get to a sound record menu.
I can't tell you how but you can find it if you click a few things.
By default, it is set to record at the lowest level & mono. You need
to up the selection to stereo, and a also to a higher sample rate. 16
bit stereo is the next highest up. Then there is higher than that. &
up. The higher the setting the more bytes it takes to record. Like
"burning" a CD at a certain rate. Try that.
Anyway, I hope that helps.
Big Mac
Reply to Anonymous
> > barely moves.
I solved the problem by connecting the headphone output to the mic input.
Strangely, when using line-in, the volume on playback was fine, but
the record volume was too low.
I did have to keep the record slider on the first notch, and the
player at about 1/4 volume to prevent distortion.
So this post is to dispel a few myths:
Myth 1 - The headphone output power should go to line-in. Not on
my motherboard.
Myth 2 - The mic input uses a poor quality preamp only suitable for
voice. When I record CD player headphone -> mic, and play back from
disk to the computer speakers, it sounds exactly the same as playing
directly CD player headphone to line-in to computer speakers.
Reply to Anonymous
There are 1119 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 16:28 bilbat won the Motherboards badge
  • 01:00 jayhsyn won the Freshman badge
  • 01:00 nesta13 won the Freshman badge
  • 01:00 petar won the Freshman badge
  • 01:00 sinsear won the Freshman badge
  • 01:00 UnawareAtol won the Uniformed badge
  • 01:00 buryaku won the Uniformed badge
  • 01:00 Redras0324 won the Uniformed badge
  • 01:00 dvdmania won the Uniformed badge
  • 01:00 ugotomega won the Uniformed badge
