Archived from groups: microsoft.public.windowsxp.general (More info?)
Hi, I'm very new to XP and am just learning about System Restore.
I need to do a registry modification suggested in a Microsoft
KnowledgeBase article. Say I first set a System Restore breakpoint. If
if anything goes wrong can I totally return to how my system was before
I attempted the registry mod? Is everything returned to exactly the way
it was?
Sponsored Links
Yes, for most of the cases.
System Restore works a lot like the Undo command in Microsoft Word. You can
use System Restore to remove any system changes that were made since the last
time you remember your computer working correctly. System Restore does not
affect your personal data files (such as Microsoft Word documents, browsing
history, drawings, favorites, or e–mail) so you won't lose changes made to
these files.
http://www.microsoft.com/windowsxp [...] store.mspx
http://www.theeldergeek.com/system_restore.htm
Regards,
Pramit Roy
> it was?
Reply to Anonymous
I shall also suggest you to kindly go throgh the following site too.It's
really very handy as far as System Restore is concerned.
http://bertk.mvps.org/
regards,
ssg MS-MVP
> it was?
Reply to Anonymous
Thanks, so this registry modification that I am about to make would get
totally undone if I do a System Restore?
In article <8B584B25-578A-4AA9-ACF3-D16609B7A68D@microsoft.com>,
PramitRoy@discussions.microsoft.com says...
> history, drawings, favorites, or eâ¤=3Fmail) so you won't lose changes made to
> these files.
Reply to Anonymous
Whats the exact mod you plan to make?
Manny Borges
MCSE NT4-2003 (+ Security)
MCT, Certified Cheese Master
The pen is mightier than the sword, and considerably easier to write with.
-- Marty Feldman
"Rick C." <blue--nospam--.heron3@verizon.net> wrote in message
news:MPG.1d95dea292daa66c9898ec@msnews.microsoft.com...
> can
> last
> browsing
> made to
> these files.
Reply to Anonymous
In article <uMt6Yx4uFHA.3548@tk2msftngp13.phx.gbl>,
manny_borges@hotmail.com says...
They're in this Knowledgebase article for Outlook:
(http://support.microsoft.com/default.aspx?scid=kb;en-us;302107)
excerpted here:
Locate the following keys for your operating system: For Microsoft
Windows NT and Microsoft Windows2000:
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows
Messaging Subsystem\Profiles\{current profile}\
After you locate the registry keys, export and delete the reference to
the Hotmail personal folders (.pst) file or the Hotmail account
settings.
Though it does make me nervous that the instructions are for Windows
2000. I'm ASSUMING they would also apply to XP...
Reply to Anonymous
Hi Rick,
Yes, System Restore should restore this portion of the registry.
Another safeguard would be to highlight each registry key (in the left pane) affected, and
do File - Export. Name and save each key to the desktop. If something goes wrong, simply
double click on the exported .reg file to merge it back into the registry.
A third option would be to backup the entire registry using Erunt.
ERUNT: The Emergency Recovery Utility NT - Registry Backup and Restore for Windows
NT/2000/2003/XP
http://www.larshederer.homepage.t-online.de/erunt/
All About System Restore in WinXP
Regards,
Bert Kinney MS-MVP Shell/User
> excerpted here:
> Microsoft Windows NT and Microsoft Windows2000:
> NT\CurrentVersion\Windows Messaging
> reference to the Hotmail personal folders (.pst) file or
> the Hotmail account settings.
> for Windows 2000. I'm ASSUMING they would also apply to
> XP...
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Help with System Restore
There are 893 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
