Archived from groups: rec.games.pinball (
More info?)
Hi
I seemed to have missed something here. Why not diagnose
the failure and replace the bad part. I looked at the kits
and it looks like one would simply replace everything.
I know most consider power supplies as being hard to
diagnose but they are not that much harder. When a supply
fails, only one or two parts have failed. Possibly one
might also replace old electrolytics that may have aged,
as well.
Wholesale replacement of parts it often more damaging.
I do know that taking the Gottlieb supply apart is a
little challenging. I've not repaired one of these but
I would never think of replacing everything.
Dwight
Steve Kulpa wrote:
> Good advise Fred! Repairing a System-1 power supply board is not for
> the timid. I repaired mine and it was a lot harder to do then the
> typical driver board, etc. Lots of stuff packed in there and lots of
> capacitors and zener diodes that have to be installed properly, plus a
> couple of parts that mount to the heat sink are a challenge, to say the
> least. If your soldering skills are anything less then top-rate, best
> to find someone who can do the repairs for you.
> Now the kits from Big Daddy are nice, and they do have all the parts.
> steve (cargbp10 - sigh)
> Fred Kemper wrote:
> > Try finding a competent repair person,
> > and have yours repaired. Once done,
> > it is a very reliable power supply.
> > Fred
> > TX
> > CARGPB#8
