Archived from groups: microsoft.public.windowsxp.general (More info?)
I'm using Windows XP Professional SP2.
I like to increase the size of my taskbar or should I say (double) its size
to two lines at the bottom of the screen in order to allow me to have more
quick launch icons readily available. This keeps my desktop relatively free
from clutter.
When I increase the size of the taskbar, and then "lock the taskbar",
everything works great until I either reboot the computer, or log off of my
profile (administrator) so that someone else can use a limited account. When
I log back on to my account the taskbar is once again at its default setting
of a single line at the bottom of the screen.
Anyone know of a way I can *really* lock the taskbar?
Read the instructions at the top.
Scroll down to...
54. Right hand side, click on...
Save Settings on Exit
Or set NoSaveSettings to 0 here...
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\
Policies\Explorer
Description
[[Prevents users from saving certain changes to the desktop. Users can
change the desktop, but some changes, such as the positions of open windows
or the size and position of the taskbar, are not saved when users log off.
Shortcuts placed on the desktop are always saved.]]
Or if XP Pro, use Group Policy...
Start | Run | Type: gpedit.msc | Click OK |
Navigate to >>>
User Configuration\AdministrativeTemplates\Desktop
Don't save settings at exit
Set it to Not Configured
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:eOezAX8uFHA.1256@TK2MSFTNGP09.phx.gbl,
WIRED <none AT hotmail.com> hunted and pecked:
> size to two lines at the bottom of the screen in order to allow me to
> have more quick launch icons readily available. This keeps my desktop
> relatively free from clutter.
> my profile (administrator) so that someone else can use a limited
> account. When I log back on to my account the taskbar is once again at
> its default setting of a single line at the bottom of the screen.
> Thanks
Thanks for your reply.
I tried the suggested fix, and then rebooted. Unfortunately it went back to
default once again. I have a strong suspicion that Ad-Watch, part of Adware
SE Professional, is restoring the default settings and not allowing me to
make changes. I have been unable as of yet to locate where in Ad-Watch I can
tell it not to do that. Or I will just be forced to unload Ad-Watch
permanently.
"Wesley Vogel" <123WVogel955@comcast.net> wrote in message
news:etfRZRGvFHA.1988@TK2MSFTNGP10.phx.gbl...
> Automated edit here...
> http://www.kellys-korner-xp.com/xp_tweaks.htm >
> Scroll down to...
> Policies\Explorer
> Description
> windows
> Navigate to >>>
> Wes
>> Thanks
Turn OFF adwatch, make changes, reboot, turn on adwatch.
> permanently.
>>Scroll down to...
>>Policies\Explorer
>>Description
>>windows
>>Navigate to >>>
>>Wes
>>>Thanks
Make sure Ad-Watch is set to "Active" and not "Automatic." If it is
"Automatic" that may be the problem because Ad-Watch will detect the changes
after you restart the PC and restart Ad-Watch and may undo them.
"Bob I" <birelan@yahoo.com> wrote in message
newsxIIqEUvFHA.2072@TK2MSFTNGP14.phx.gbl...
>> to default once again. I have a strong suspicion that Ad-Watch, part of
>> Adware SE Professional, is restoring the default settings and not
>> allowing me to make changes. I have been unable as of yet to locate where
>> in Ad-Watch I can tell it not to do that. Or I will just be forced to
>> unload Ad-Watch permanently.
>>>Scroll down to...
>>>Policies\Explorer
>>>Description
>>>windows
>>>off.
>>>Navigate to >>>
>>>Wes
>>>>Thanks
