Closed Solved
Will a cheap gold-plated audio cable be ok for this setup?
Hey everybody,
Here's the situation - I'm keen on buying a "LASER BLU-BD1080" Blu-Ray player so I can hook it up to a Logitech Z506 5.1 surround sound system (mainly because the BR player has in-built analogue audio decoder) and I need 3 x 3.5mm to 2x RCA cables to make this work.
Keeping in mind that I don't need anything more than about 1.5m length would the real cheap cables with gold-plated connectors be ok to carry the 6 channel sound between the two devices or is it worth paying a bit more if it means better quality sound as a result?
I know that this subject can be highly debatable amongst enthusiasts but I just need to know straight up if these cheap cables found on ebay would suit this particular setup (the ones I'm looking at are around 4 AUD each).
Thanks in advance for any help :D
3 answers Last reply Best Answer
More about will cheap gold plated audio cable setup
  1. Best answer
    The standard type of affordable cables, with gold plated plugs will be great.
    Spending a lot on cables is a waste, and unnecessary. Regular cables are just as good as the really expensive ones.
  2. Best answer selected by Trist_58.
  3. This topic has been closed by Nikorr
Audio Cable
