I am ready to take the newbie plunge into overclocking and I think this will be the base from which I will start;
P4 2.8E (Prescott)
ABIT IC7 Mobo
DDR400 (PC3200) Crucial RAM (2x 512MB)
I already have the RAM so the Mobo and CPU will run ~$350. Is this the best way to start? What other mobo/cpu combos might be better? Thanks.
PS Try to stay on subject. I am not using AMD and I'm not buying newer RAM (yet).
I agree that the Northwood cores run cooler and OC well in their own right. Also, a mobile Barton and NF2 combo would guarantee you a successful experience, better temps and good performance. If you want to stick with the Prescott, check this article:
http://www.hardocp.com/article.html?art=NjAz and remember, cooling is also important-the lower your temps at stock, the better your chances of a great OC.
The Crucial PC3200 might get you to a 225mhz FSB. Don't expect any more than that. Of course, if you start from 3.2 ghz that won't be too shabby at all.
"I am become death, the destroyer of worlds. Now, let's eat!
PC3200 RAM won't get you too far with Intel unless you have a really fast processor to begin with (3.2C or 3.0C) and if you get one of those you kinda miss the point of overclocking - getting more for less. So AMD is your best choice - the A64 systems are good performers, but if you're looking for the max OC % the 2500+ MOBILE Barton rules the earth, AND you can still use that RAM and get great results. Also get some 1337 heatsink, though you probably won't even need it to get to 3200+ speeds (11x200). Also 1337 about MOBILE Bartons is their unlocked multiplier, search boards for why this is important.
Post your question at the best overclockers forum
<A HREF="http://www.xtremesystems.org/forums/forumdisplay.php?s=a91770c8a42178dcb2ef1715f4691440&forumid=59" target="_new">http://www.xtremesystems.org/forums/forumdisplay.php?s=a91770c8a42178dcb2ef1715f4691440&forumid=59</A>
Thanks for the advice so far. I think I will take to heart the advice to go with a non-prescott chip. Given the goal to have a HOT (pardon the pun) gaming machine I think the 3.0C is good advice given the limitations on the Crucial RAM. I'm not sold on the Mobo yet so keep the suggestions coming.
"Devils are those who do evil, or prevent others from doing good, or who do nothing at all" - Goya
