G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Solved... I think. Thanks go out to Fred Kemper and Otto and any others who
replied that I didn't see (I lost Internet access a couple weeks ago and just
got it back).
They suggested that the problem was with the EOS switch but I refused to
believe it since I had checked it MANY, MANY times. After exhausting coil
homing, voltages, wiring, etc., I had to go back to the EOS.
Freakiest problem I've encountered! The blade that the crank pawl pushes
away to open the points had a hairline crack right at the point that it joins
the formed plastic housing and left the points open by a gnats ass or .0001
whichever is smaller... to my old eyes, too small to see but no high voltage
was passing.
While removing it the blade just fell off, confirming the "hairline" crack
Trying to find one locally but will probably have to order one. will let you
know how it turns out.
Ron -- CARGPB7
ronstr@asisnotapplicable.com (change not applicable to na)
got it back).
was passing.
Ron -- CARGPB7
