Is it worth getting a sound card when i have an amp
I have recently bought a second hand Denon 5.1 surround sound system and currently use
run my PC off it, I'm toying with the idea of getting a decent set of head phones (£60 ish mark)
for music and gaming use (From what I've read gaming headsets should be left alone). Is
It worth me getting a decent ish sound card as well or would the amp be enough? I'm not a
massive geek on the sound side of things but wouldn't mind a decent set up. also I have an
old pair of Senhiser HD500 given to me that i've been toying around with running right off my
PC, it does make things a bit better in terms of gaming and music wise they're ok, but at the moment
they're just running right of my PC as i don't have an adaptor for them to work through the amp yet.
any advise would be most welcome.
2 answers Last reply
More about worth sound card
  1. If your current soundcard does not have digital audio outputs and you are connected with analog audio then one that does should give you an improvement in sound. That assumes that the Denon has digital audio inputs.
    Just adding to what americanaudio said...
    I would suggest getting one just for the digital audio outs but only if you don't have them already. If you do need one just get a decent one since your receiver will do most of the work anyway it just needs the signal.
Gaming Sound Cards Audio
