G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
i just recently got xp upgraded from Windows ME , now im having problem
with my sound for example when playin music during music when i
minimize or move my mouse it makes horrible noises from the speakers ,
i never had that problem with windows ME is it my sound card that does
not go with Xp and do i need a new one , it was ok with ME , but xp my
sound is not good what can be the problem any suggestions pls thanks
ace_786
Malke
3,000
> problem with my sound for example when playin music during music when
> i minimize or move my mouse it makes horrible noises from the speakers
> , i never had that problem with windows ME is it my sound card that
> does
> my sound is not good what can be the problem any suggestions pls
> thanks
Update the drivers for your soundcard, using ones designed for XP. Get
the drivers from:
1. The card mftr.'s website; OR
2. The motherboard mftr.'s website if onboard video; OR
3. The OEM's website for your specific machine if you have an OEM
computer (HP, Dell, Sony, etc.).
Read the installation instructions on the website where you get the
drivers.
If you are unsure what soundcard you have, use the free Everest Home
system inventory program:
http://www.lavalys.com/index.php?page=product&view=1
Malke
MS-MVP Windows User/Shell
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic"
G
Guest
Guest
A few things:
1) Update all drivers to XP versions, including motherboard chipset drivers
and sound card
2) Remove sound card drivers from Device Manager and shutdown your PC.
Then, open the casee and re-seat the sound card. Close the case and reboot.
Re-install XP sound card drivers.
3) If mouse is a corded unit, route the cable away from the speakers.
"ace_786" <ace_786.1vkf1n@pcbanter.net> wrote in message
news:ace_786.1vkf1n@pcbanter.net...
> ace_786
