This is my receiver which has 1 sub-woofer pre out....http://www.newegg.com/Product/Product.aspx?Item=N82E16882117395
This is my sub-woofer which has right left connectors...which equals having to run 2 cables/connectors to the sub-woofer....http://www.newegg.com/Product/Product.aspx?Item=N82E16882117402
My question is being as though my subwoofer has 2 cables that need to be run to the receiver...how do I hook it up/connect it if my subwoofer has only 1 plug/pre-out.
I have 10-15 RCA cables and Monster cables around my house.The answer is not as simplified as just connecting A to B...if that were the case then I would not be asking the question.Someone said for me to use RCA jacks...well,same existing issue..2 connectors 1 pre-out.What to do?
