Solved
Spot on my hp monitor whats wrong
  • CRT Monitors
  • Hewlett Packard
  • Monitors
  • Peripherals
Last response: in Computer Peripherals
May 30, 2011 1:07:37 AM
Hello, I have a dime sized black spot at the bottom of my less than 1 year old HP flatscreen monitor. What is this and can I get rid of it?
More about : spot monitor whats wrong
Best solution
a b α HP
a c 115 C Monitor
June 1, 2011 8:25:15 PM
Less than 1 yr should be under warranty, exchange it. LCDs are Liquid (the L part), sounds like you have some leaking crystals. Bit like a down comforter with pockets, if a pocket breaks, the down inside it starts to move around losing it's shape. Could also be excessive heat that causes this.
June 8, 2011 3:53:56 PM
Best answer selected by LoveMonkey69.
m
l
June 11, 2011 2:03:20 AM
Well, whatever it is, it's getting smaller. It's almost non-extent now.
m
l
