Solved
Eyefinity Help
Last response: in Computer Peripherals
June 7, 2011 7:54:02 PM
Hello, my new PC is going to have an AMD Radeon 6950, and I don't plan on unlocking it btw. I was wondering if I would have any issues setting up Eyefinity (3 monitors) with 3 ST2220M 21.5 inch Widescreen LCD Panel Monitors?
Thanks in advance! =)
More about : eyefinity
Best solution
June 11, 2011 4:58:19 PM
Nope, shouldn't have any problems at all, great card for the price. You will need an active display port adapter for your third monitor, but those can be found for about $25 nowadays.
a c 193 C Monitor
June 11, 2011 6:36:08 PM
Get the 2GB version since you need that for all the textures that will be loaded onto the HD 6950 at such high resolution.
June 28, 2011 6:58:32 PM
Thanks everyone for helping! I'm actually getting my computer from custompcandrepairs.com
And wow they've been great to me! They ran benchmark tests and did countless things so I can get the best PC for me. I just thought I'd let you guys know about them, because they are a great company
June 28, 2011 7:07:38 PM
Best answer selected by socks.
