Archived from groups: alt.os.windows.xp,microsoft.public.windowsxp.general,microsoft.public.windowsxp.help_and_support,microsoft.public.windowsxp.network_web (More info?)
Hi,
I have purchased a WinXP (HomeMediaEd) last month. I have it networked into
the existing LAN at home that hosts other machines (WinXP, 2K, Linux,
Solaris).
I noticed a strange phenomena and I need some expert help/suggestion: The PC
loses network connectivity when the screensaver kicks in! I have checked the
power options - and they are set to "Turn of Monitor after 5 hours" and it
does not seem to influence. What am I missing?
Once I move the mouse to exit the screensaver, it all comes back to normal
(and the BitComet would try and re-establish connection). During the time
the screensaver is on, none of the other computers on the LAN can reach it.
Also, it does not matter what screensaver I choose.
> What are the power settings?
> Control Panel > Power Options.
As I have said in my post above, the power settings are "Turn off Monitor
after 5 hours". In other words, this is how the settings look:
Turn off Monitor: After 5 hours
Turn off hard disk: Never
System standby: Never
System hibernates: Never
>SB
What are the power settings for the network adapter? If "Allow the computer to
turn off this device to save power" is enabled, you will indeed lose network
connectivity when power management kicks in. This will be about the time that
the screen saver is activated.
Cheers,
Chuck, MS-MVP [Windows - Networking]
http://nitecruzr.blogspot.com/ Paranoia is not a problem, when it's a normal response from experience.
My email is AT DOT
actual address pchuck mvps org.
