evilsnip3r
well before i go buy an A64 does anyone know if i need a special kind of hs for the cpu?
right now im using an SLK-800 for my 2800+ and i was wondering if i could still use it on a K8N Neo from MSI.
Cybercraig
2,058
Probably not. The mounting scheme is different on the 754 socket. You can use an Opteron heatsink and a Thermaltake fan if you want.
"I am become death, the destroyer of worlds. Now, let's eat!
scottchen
Splendid
Jun 3, 2003
5,791
You cannot use the SLK800, the only thing socket754 takes from thermalright is the SLK948U.
Just to let you know, the stockcooler kicks ass, it handles 1.7Vcore perfectly(maximum recommended by AMD). Its fan speed adjusts from 2500RPM-5500RPM, if you're just into moderate overclocking, then stockcooling will be just fine.
<A HREF="http://www.ebaumsworld.com/celebgay.html" target="_new">click here now!!</A>
<A HREF="http://www.ebaumsworld.com/epilepsyr.shtml" target="_new">DON'T CLICK HERE!!</A>
davemar14
777
The Thermaltake Silent Boost is a good heatsink/fan. It does a good job of cooling your CPU, while keeping the noise down. And you can get one for less than $40.
My System:
<A HREF="http://www26.brinkster.com/amdgamer1/main.html" target="_new">http://www26.brinkster.com/amdgamer1/main.html</A>
scottchen
Splendid
Jun 3, 2003
5,791
$40?! you mean canadian right? because they can be found in the US for about 20 if not less. And in canada they can be picked up a little over 30CAD.
davemar14
777
Newegg is selling the Thermaltake Silent Boost for $29.99. Once you add shipping, it may be a little less than $40. In any event, its a good price for a good cooling heatsink.
scottchen
Splendid
Jun 3, 2003
5,791
I would still go with the Venus series because if you turn the noise levels to the same the Venus 12 will outperform the silent boost.
DonnieDarko
653
The stock heatsink is pretty good that comes with the a64. I have mine at stock speeds right now with temps in the 30-40 range.
AMD64 2800+
MSI Neo-Fis2r
512mb Kingmax ddr400
Sapphire 9800pro 128mb
10K WD Raptor<P ID="edit"><FONT SIZE=-1><EM>Edited by donniedarko on 06/15/04 00:27 AM.</EM></FONT></P>
TheRod
2,031
Someone recommended me the ThermalTake Venus 12 which is 28,99$ on NewEGG. It's on my current wishlist. But I really don't know how it compares to Silent Boost.
What's the <b><font color=green>AMD Mobile Athlon 64</font color=green></b> overclocking potential? <b>It's huge!</b> Humm... Maybe not that huge...
Check newegg's refurbished section. I've seen the thermaltake k8 venus heatsink for about $16. They also have a watercooling kit for about $76. I don't recommend water cooling unless you have alot of experience and patience. Globalwin has a silent stream water cooling rig that's very easy to use. It's $65 at ewiz.com.
