Tales from the crypt lamp problem
Archived from groups: rec.games.pinball (More info?)
Well the Yellow/Brown and Yellow/Red (Bulb 1-16) is dead on my TFTC.
Also 50% (The lower left part) of the backbox lamps are dead.
Cant really be a fuse, can it? I have check the wires.
3 answers Last reply
More about tales crypt lamp problem
  1. Archived from groups: rec.games.pinball (More info?)
    I would check the voltage at the board then down the line. I had a
    problem like this on my Star Wars. I had a short in one of the
    connectors.
    Jeff
  2. Archived from groups: rec.games.pinball (More info?)
    Why check wires first with that many bulbs out ? Power off remove fuses and
    check. Then on the power supply board, check if the connector for those
    bulbs is burned. LTG :)
    <gambit@spray.se> wrote in message
    news:1124525529.529232.135160@g47g2000cwa.googlegroups.com...
  3. Archived from groups: rec.games.pinball (More info?)
    It's always the circle of 3: a fuse, a wire or a connector. Or a combination
    of little bit of all. You have to be meticulous in your diagnosing and
    you'll find it.
    Adi
    www.txpinball.com
Games Video Games
