Tom's Hardware > Forum > CPU & Components > CPUs > Stability problem (I think)
Forum CPU & Components : CPUs - Stability problem (I think)
hey everyone,
I have been noticing some problems with my system. I built it a few years ago, but have upgraded the processor about a year ago, and a few other parts here and there.
The system seems to sort of skip sometimes. Like when I'm playing music with certain programs it will skip every once and while.
The main problem I'm having is with ripping MP3s, I can rip them fine, no errors, I've tried neoaudio, musicmatch, ect..., with all sorts of different compression settings, and the MP3s play fine on my computer, but then I try to play them on external MP3 players, like the one in my car and they have all sorts of imperfections in the tracks. The reason I think it's my computer is because when I download songs off line, or get them from friends computers, they don't have the imperfections, I thought it was a problem with my burner, but I can put downloaded songs on CDs with ones I've ripped and the ripped ones are messed up and the downloaded ones are ok.
does anyone have a guess as to why my system might be doing this, or if maybe it could be something else. I've made sure not to run many programs, or any at all, while ripping or doing whatever. It doesn't seem to make a difference.
Here are my specs.
SiSoftware Sandra
Processor
Model : Intel(R) Pentium(R) 4 CPU 2.80GHz
Speed : 2.81GHz
Performance Rating : PR3732 (estimated)
SMT Support : 2 Unit(s)
Type : Standard
L2 On-board Cache : 512kB ECC Synchronous ATC (8-way sectored, 64 byte line size)
Mainboard
Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus
MP Support : 1 CPU(s)
MP APIC : Yes
System BIOS : American Megatrends Inc. 1008.004
System : To Be Filled By O.E.M. To Be Filled By O.E.M.
Mainboard : ASUSTek Computer Inc. P4P800
Total Memory : 511MB DDR-SDRAM
Chipset 1
Model : Intel Corporation 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface
Front Side Bus Speed : 4x 200MHz (800MHz data rate)
Total Memory : 512MB DDR-SDRAM
Memory Bus Speed : 2x 200MHz (400MHz data rate)
Video System
Monitor/Panel : Gateway VX900T
Adapter : NVIDIA GeForce3 Ti 200
Physical Storage Devices
Removable Drive : Floppy disk drive
Hard Disk : WDC WD600BB-23CAA1
CD-ROM/DVD : PIONEER DVD-ROM DVD-106
CD-ROM/DVD : PLEXTOR CD-R PX-W4012A
Logical Storage Devices
1.44MB 3.5" (A:) : N/A
Winxp (C:) : 24.4GB (20.5GB, 84% Free) (NTFS)
Data (D:) : 31.5GB (14.4GB, 46% Free) (NTFS)
Sb_install (E:) : 628MB (0MB, 0% Free) (CDFS)
CD-ROM/DVD (F:) : N/A
MultiMedia Device(s)
Device : Creative SB Audigy
Device : Creative Game Port
Power Management
AC Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP/2002 Home (Win32 x86) 5.01.2600
Network Services
Adapter : 3Com Gigabit LOM (3C940)
Thanks.
-Dave
Sponsored Links
Try updating your soundcard drivers..
= The views stated herein are my personal views, and not necessarily the views of my wife. =
Reply to P4Man
Thanks, I'll give it a try, but would that have any effect on how CDs are ripped?
Reply to davess4
You might want to run memtest86. Try to use your burner in a different computer.
Reply to endyen
YOu might want to check out www.cdfreeks.com forums those guys know everything about ripping and burning.
Also dude get a video.
40k in aquamark 3
<A HREF="http://arc.aquamark3.com/arc/arc_view.php?run=77119011
" target="_new">http://arc.aquamark3.com/arc/arc_view.php?run=77119011
</A>
P4b2.4@2.8||1024mb DDR@392mhz||9800pro@414/732||Viewsonic UltraBrite 19"||Panisonic DVD-RW<P ID="edit"><FONT SIZE=-1><EM>Edited by pukepile on 06/20/04 08:39 PM.</EM></FONT></P>
Reply to PukePile
There are 515 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
