Archived from groups: rec.games.pinball (
More info?)
Those are your Gi strings.
Go into general illumination test and figure out which strings are involved.
The Gi strings are also described in the manual inside front cover towards
the bottom.
Turn off power.
Then go to the fuse list page in the manual pg 1-43 and determine the fuse.
Will be F106-F110.
Remove the fuse(s) and check for continuity. If bad, replace.
Check the bulbs. They may all be burned out.
If the fuse is good and the bulbs are good, then you have to start checking
the connectors and header pins. J120 and J121. If brown or burned you
probably need to replace the header pins on the board and the connector
housing.
The top videos show you how to do this or see Marvin.
http://marvin3m.com/wpc/index.htm
Hth.
Otto
CARGPB11
My web page:
http://home.bellsouth.net/p/PWP-Ottoslanding
<gambit@spray.se> wrote in message
news:1124630880.309817.112100@g43g2000cwa.googlegroups.com...
> Only the big flashing bulbs are working.
> Is there a fuse for the others or do i have a bad cable?
