Best 'First' Laptop for Software Graphics, Speed?
patty351
Hello,
I plan to buy a Sony Vaio as my daughter's first laptop. She liked one in store with Core i3, 500gb hardrive, & 256 mb dedicated video memory (2007 total), plus GForce 310m graphics. She mostly surfs and plays Sims 3. I'm considering a slightly cheapter version (both have 4GB memory!!) with 325 drive and 1726 video (no dedicated). Can this do the job? Its much more than I have now!
IsabellaWinTeam
445
Hi there,
I assume the laptops you are looking at are going to run Windows 7? Check with the Sims 3 software in order to find out what the minimum system requirements. The Sims 3 is a graphics intense came so be sure that the laptop you select will be able to handle it,
Let me know if you have any other questions.
Cheers,
Isabella
MSFT Windows Outreach Team
