VGA Problems
Last response: in Laptops & Notebooks
June 16, 2010 4:26:26 PM
Hello everyone,
Please my notebook G6000's screen is all pink. Does it have anything to do with my VGA?...pls assist
More about : vga problems
Anonymous
a b D Laptop
June 16, 2010 10:57:47 PM
If possible connect the laptop to an external screen and see if that's okay. This should help you isolate the cause.
If the external is a bit pink too, it's most likely a software issue or a fault with the video chippery.
If the external is okay, then it suggest a fault with the laptop screen or its connector cable to the motherboard.
