Archived from groups: microsoft.public.games.zone (
More info?)
anonymous@discussions.microsoft.com wrote:
> >-----Original Message-----
> >dan wrote:
> >> I can't seem to get anywhere with getting rid of the
> >> Failed to Download error. I've tried all the ideas I
> >> know how to do. I tried to just delete the whole MSN
> >> Games folder, but it wouldn't let me do it because
> >> apparently something in that folder is protected, or in
> >> use. No programs are running that I can tell. When I
> go
> >> into the folder, select all, and delete, all files are
> >> deleted. However, the file icons pop right back up in
> >> the folder, even though the files are now in my trash
> >> can. The files just can't be deleted, and none of them
> >> are write protected or anything. What can I do?
> >> thanks,
> >> dan
> >With XP, the files are considered system files. To
> remove the Zone, Use
> >the Add/Remove Programs in Control Panel, click the
> Windows Components
> >in the left column, locate the Zone in the Games
> section, and deselect
> >it.
> >Have you tried the suggestions here?
http://www3.sympatico.ca/nibblesnbits/EnterRooms.html#f...
> Yes, Elmo, I've tried just about everything. I didn't
> contact my ISP (optimum online) because I didn't know if
> this applied to me. I have:
> - checked the firewall, which I disabled
> - turned off any virus checkers and pop up blockers
> - cleared the cache
> - deleted heartbeat
> - deleted any conflicts with zextract.exe
> - deleted MSN Games through both add/remove programs and
> just now from your advice above, through Remove
> Components. The components are gone, but the folders are
> still there and won't go away, if that matters.
> - tried everything else on sympatico except getting the
> files off another computer, which I don't have.
> One thing that has been happening is that every once in
> awhile I get a message that "there is a network cable
> unplugged" and a little icon of a computer with an X on
> it comes up on the system bar near the time. I have no
> network and don't know how to stop this error. Maybe it
> is causing a problem??
I doubt it's causing the problem, but right-click the icon in the tray,
look at the Network components, and disable the network card. That
should prevent the error message in the future. Make sure the Windows
firewall is disabled, till the Zone is installed correctly. There are
many problems associated with NIS and the Zone. Here's a link to a
search result:
Click the different "View Thread" icons that look like they might apply
to your situation, if you have NIS.
> Thanks. I never got your emails, but I'm not sure it
> matters. Mine is dwhite110@optonline.net
> dan
+Elmo_Tech
MSN® Gaming Zone™ - Technical Support
clvck
