QC3 + Xonar DGX = horrible sound
September 19, 2012 3:55:54 AM
about $440 of equipment and it sounds pretty bad.
QC3
- makes sounds noticeable that arent noticeable on speakers or cheaper headphones. so you hear every bad thing in low quality audio
DGX
- bad.. just BAD. so bad something must be wrong.
- there is an slight echo with no apparent way to turn it off
- none of the presets make anything sound good
- messing with all the equalizers and options doesn't help
I think the problem is a combination of low quality audio and untuned equipment.
