Ok, I got a new mobo and case and I wanted use old CPU and memory just so I could use the new stuff I got. I've got a NF7-S, 256mb Nanyo PC2700, Samsung 128mb PC2100, and Maxtor 80GB 7200rpm 8mb cache. I just took the hard drive out of my old computer which has Windows XP Home Ededition on it. I didn't restore it or anything, just stuck it straight in there. The Windows XP Restore disk I have came with my old Emachines computer. I was wondering if it wasn't working because there are drivers and stuff on there that won't work with my new computer? The problems that I'm expieriencing are..it seems I can start off fine, and I can get into BIOS fine, but when I start up it goes fine right up until the Windows loading screen. It's almost there and then a blue screen flashes and I think I can see something about hard drives and then the computer just restarts. I'm also getting a short and then long beep right when I startup the computer. Is this a RAM issue or hard drive issue?
<b>!bang-o-rang</b> <b>Go to my website --><A HREF="http://www.bantheman.us" target="_new">http://www.bantheman.us</A></b>
