Help me finding laptop model
sharique
11
1_What is your budget?
US ~$900 (INR 40k)
2_What is the size of the notebook that you are considering?
15 inch or higher
3_What screen resolution do you want?
no particular choice
4_Do you need a portable or desktop replacement laptop? either is ok
5_How much battery life do you need?
2-3hrs or more
6_Do you want to play games with your laptop? If so then please list the games that you want to with the settings that you want for these games. (Low,Medium or High)?
Yes, NSF series and Age of ampires
7_What other tasks do you want to do with your laptop? (Photo / Video editing,watching movies, Etc.)
occational watching movies, playing games
very little photo editing,
rarely video conversion,
8_How much storage (H.D.D Capacity) do you need?
500 gb +
10_How long do you want to keep your laptop?
atleast 2 yrs
11_What kind of Optical drive do you need? DVD ROM/Writer,Bluray ROM/Writer,Etc ?
dvd-writer
12_Please tell us about the brands that you prefer to buy from them and the brands that you don't like and explain the reasons.
I will prefer to buy from these brands, I have seen and used thier laptop, that is the main reason to like them.
Toshiba (it is more duarable),Acer, HP,Sony.
13_What country do you live in?
India
14_Please tell us any additional information if needed.
I'm a developer but I'm going to do all sorts of things, may run win7 in vm on linux.
I prefer AMD processors. I think Phenom II triple core is the most suitable for my needs. I still need to find exact model for purchase.
Laptop with Linux or no OS is better option, because I use Linux as primary os.
I can buy from outside of India but it depends on my friends visits. You can also suggest models which are available in S Korea and Singapore.
