Solved
Audio System ?
Hey guys,
I have a 32" Vizio with an offbrand soundbar that has two AV outputs and one input. I am also building a media server PC to always be connected through a VGA cable to the TV for movie streaming and music playing purposes.
I was interested in attempting to find an audio system that will be possible to wire all of these together.
PRice range: Less than $200, if possible less than $100 but for a good system that will last I will spend a little extra
4 answers Last reply Best Answer
More about audio system
  1. There are many possibilities. Give us two stores/websites you would shop at and we can make some recommendations.
  2. Newegg, amazon, best buy
  3. Best answer
    well you have a few options available to you.
    you could connect both up to the television and use the televisions audio out to go to the soundbar
    you could have a seperate wire going from each source to the soundbar and use a splitter (but you could only have one device set to output sound at once this way)
    a hometheatre in a box solution might accept two inputs and act as a cheap receiver/speaker combination, however the speakers you will get are typically little junky plastic ones so i find this hard to recommend.
    you could link both through a cheap receiver and get a few speakers to hook up. this way might blow your budget by a little bit.
    personally i have my ps3 and pc hooked up via a receiver and that connected to a 5.1 surround system and 40" tv. i spent quite a bit more than $200 (i had a bigger budget) but overall i'd say its worth it.
  4. Best answer selected by techo.
Audio Peripherals
