HP Mini 210-1084TU XP installation problems
Hi, Yesterday I bought a HP Mini 210-1084TU with FreeDos since I have a Windows XP SP3 Disc with me. I have tried various methods but all bore no fruit :(
methods I tried
http://h30434.www3.hp.com/t5/Operating-systems-and-software/SATA-drivers-for-XP-solution-on-0x0000007B-BSOD/td-p/114120
http://translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=1&eotf=1&u=http%3A%2F%2Farieksinggih.wordpress.com%2F2010%2F02%2F02%2Finstal-
xp-di-hp-mini-210%2F&sl=auto&tl=en
In above method with or without slipstreaming sata drivers there occurs an BSOD with STOP: 0x0000006B (I'm sure its 0x0000006B)
I have also copied all the files to a thumb drive and started the setup from dos mode \i386\winnt.exe
I had to stop midway as setup kept reporting numerous files missing.
I have also tried more than one copy of Windows Xp Setup with success at all...
Any Suggestions ? solutions? working methods?
2 answers Last reply
More about mini 1084tu installation problems
  1. helo every1..i have a problem...my hp mini 210-1000 and im having problem installing XP from a USB..i used usb multiboot and window xp and also pendrive with 16gb...but every time it loads all the installation files in the text mode setup and I end up getting a blue screen. I've tried everything and I can't even get to the UELA. Can someone please help me, I thank you in advance. pls email or send a reply...pls...urgent....i need netbook for my project
  2. Hello, did you get this work ?
    I'm having same laptop (mini 210 - 1084tu) and I had same problems with installing win xp sp 3 however , just few days back I solved it using slipstreaming and nLite software.The problem is , the OS which you are trying does not contain the drivers for Harddisk.
    To slipstream you will need the following driver for the drive.
    http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=ob-54270-1&jumpid=reg_R1002_USEN
    For nLite use the following URL for "How to ?"
    http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html
HP Mini Windows XP Laptops
