I just had a local shop assemble the following PC for Photoshop (including RAW conversion with C1LE), video editing, music, and all the normal Office and web uses (not a gamer, sorry):
P4 3.0E, Asus P4C800-E mobo, 1 GB Kingston RAM, ATI Radeon 9600 SE (128 MB), HDs as shown below, Lite-on DVD-ROM and 8x DVD-burner (separate), Impressions case, internal card reader, etc.
For the hard drives, I went with a 37 GB Raptor for the OS/Apps, 2 WD 160 GB drives in Raid 1 for Photos, and put my existing 40 GB WD IDE drive in for music storage (this will also give me plenty of options for the swap file and scratch disk).
Here's the problem. THIS THING IS SO LOUD IT SOUNDS LIKE THERE'S A BLOW DRYER INSIDE THE CASE. I've isolated the noise; it's all coming from the CPU fan (when I unplug it, the machine is whisper quiet).
I find it hard to believe that this chip is supposed to be this loud (FYI, from the BIOS, I can see that the chip is at 50-degrees and the mobo is 36-degrees). The shop is going to try a different fan, but does anyone have any other suggestions. I've heard great things about this chip, but if you have suggestions for other chip/mobo combinations that deliver similar speed (even for more money), I'm willing to try it. I use this computer in our bedroom; if it stays this loud, I don't even know if the basement will be an acceptable home.
Thanks,
Steve
Thanks,
Steve
