Best way to connect my motherboard to my home theater system?
I've been having trouble setting up audio from my computer to home theater system. I have a M4A88TD-V EVO/USB3 motherboard and the home theater system is a coby csp96. I'm confused how I should connect it. Also if it makes it better for it to go through my tv idk if that would give more options. link below
http://www.asus.com/Motherboards/AMD_AM3/M4A88TDV_EVOUSB3
http://www.cobyusa.com/?p=prod&prod_num_id=311&pcat_id=2004
http://westinghousedigital.com/products/lcd/up-to-26/vr2680df/
1 answer Last reply
More about best connect motherboard home theater system
  1. im assuming your sound system has 3 plugs right, in 3 different colours... just match those colours to the ones in the cluster of 6 round audio connections at the bottom of your motherboard I/O..
    and whenever you can.. Don't run through a tv.. for the best audio quality try to run the signal through as little devices as possibile
High-End Audio Home Theatre Connection Motherboards Audio
