A good friend of mine is going to school and he wants me to build his computer. He's a mild gamer, but most of his classes are CAD based and whatnot.
In honest opinions hopefully backed with some benchmarks what do you think his best possible solution would be for a gaming/cad rig?
I was shooting for a possible opteron, but i don't really know if that would help him any with games.
I also thought about an A64, but i don't know if i can truley trust the mobo selection that is out. It's almost too new for me to say if it's good or not.
And obviously i'm going to go P4 if i go below those, but i don't want to give him a space heater. I'd like to give him something that will be higher end for at least a year and a half.
I'm just starting to look around now, but i really would like input from all of you on which would help him the best.
I do know i want to build him a better machine than a p42.6c rig, and a good thing to note though.. he's used to an old p3 500mhz w/256mb of ram. windows 98. So anything will be godly to him now.
<A HREF="http://arc.aquamark3.com/arc/arc_view.php?run=277124623" target="_new">http://arc.aquamark3.com/arc/arc_view.php?run=277124623</A>
46,510 , movin on up. 48k new goal. Maybe not..
<A HREF="http://www.anandtech.com/guides/showdoc.aspx?i=2122" target="_new"> this </A> might be more helpfull than the 50 posts that are about to follow
= The views stated herein are my personal views, and not necessarily the views of my wife. =
A64 3200+, MSI N8N Neo Platinum, 1GB of Corsair Value RAM, 200GB WD SATA, 400W power from Fortron, 6800GT, any case that looks pretty.
Thats what i would buy. i dont know your budget but that is a HUGE upgrade from that old computer and its a great bang for buck machine.
If you want to go high end...
i would go
A64 3800+, Gigabyte K8NSNXP-939, 1GB of Dual Channel RAM name brand, Raptor 72GB or two WD 80GB SATA in RAID-0, 450W Fortron power, 6800Ultra, and a nice pretty case.
You can mix the higher CPU with the lower HD, Graphics card, power, and RAM.....it will save you some money. Its all about how much your friend wants to spend.
What do you call a group of midgets? A pack, gaggle, a pride, or maybe just a murder?
well depending on your friends needs, what is more important to him? CAD or Gaming? if school comes first, then i would say CAD is more important, then the P4 is the best choice for him. the P4 is superior to the A64 in 3d studio rendering and Lightwave 7.5. <A HREF="http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2065&p=11" target="_new">http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2065&p=11</A>
of course for gaming the A64 is better because of onboard memory controller, <b>but</b> not by much.... i am living testament to that. My P4 is quite adequate and up to the task if necessary, and is no more than 10% slower in some games!!!
For most CAD progs, the AMD chips are better. In games the AMD chips are better.
I am not secure enough with the 939 mobos to recomend one. For socket 754, the nforce3 250 chipsets are best. Check out the Asus K8N-E Deluxe.
Since the recent price drops, the A64 3200+ has become reasonable.
I cant bring myself to suggest the high end graphics cards, but at $225 or so , the R9800pro is a great buy.
I was pretty much sure of getting him a pentium, but i don't really know much about CAD, i have heard pentiums are better at that task.. but why exactly?
I'm a CAD newb. Never even looked at it before.
Another thing.. that 10% less in games he wont notice. That's only something that we would notice... and therefor i believe i'm trying to focus on CAD more.
46,510 , movin on up. 48k new goal. Maybe not.. <P ID="edit"><FONT SIZE=-1><EM>Edited by Johanthegnarler on 08/13/04 10:14 PM.</EM></FONT></P>
That's interesting you say that.. i do know before the a64 it was p4 for CAD, but now that i'm looking at other sites(that i can't trust) they are showing athlon MP's owning in CAD.
But i think it would be better for him to go single CPU, and i was also thinking 9800pro for him as well. He's not a crazy doom playing fiend, but he loves halo, and battlefield vietnam.
i see that the added sse2 to the a64 has helped improve it's scores in CAD.
46,510 , movin on up. 48k new goal. Maybe not.. <P ID="edit"><FONT SIZE=-1><EM>Edited by Johanthegnarler on 08/13/04 10:02 PM.</EM></FONT></P>
You said you want something faster then a P4 2.6C
you pretty much are looking at AMD then.
Well i guess you if you need a space heater you could get a P4E....but you said you didn't want high temps.
Also different CAD programs require different uses. Some favor AMD, some favor intel.
if all call those a tie, AMD has MUCH lower temps then the P4E. Gaming would be MUCH faster.
If you go INtel find a P4 2.8C and overclock it to 3.6. The temps would be lower then a P4E and its cheaper.
Welp, i'm going to ask him what exact programs he's going to use. And there is no way i'm overclocking a machine for him, mainly due to me being a few hours away from him if anything goes wrong. ^^ Although i'm pretty damned good, i feel that should be his choice.
Also, he did say he wanted his case to be as quiet as possible. But.. everything else i'll worry about once i figure out which cpu to get him. If it was me i'd go A64, but i'm not setting it into stone untill i read everything i can read. HOpefully from real experiences.
in one of your own clickys you show the LOWEST A64 out the 2800+ beats the P4EE(which is about 800% of the cost of a 2800+) in compressing files.
For lightwave the 3800+ (which i recomended for a top end setup) is 8% faster then any P4...and its not even the quickest.
Intel does have a whopping 14% lead in the 4D rednering, a 4% lead in 3D studio max,
I quote from the conclution of that article
"A look at the benchmark results reveals that there are only few areas where Intel dominates. While the synthetic benchmarks often speak in favor of Intel's 3+ Gigahertz chips, there are only few real-life applications left that run better with Intel inside: audio/video encoding and some rendering applications. Games and multimedia applications have already been a domain of AMD's Athlon64, and the new Socket 939 processors underscored that fact."
It all depends on what CAD programs are being used. Some favor intel and some for AMD. But i like AMD for cost and for heat, and for gaming.
Kanavit says 10%....what about Doom3? the highest demanding game so far....on Anandtech.com....kanavit is 21% behind the 3800+ and 25% behind the #1 chip.
I say AMD can hold its own in CAD because it doesn do well ine some of them, but intel can't hold its own in gaming, or keeping itself cool, or even in pricing.
Its pretty hard these days to say one is faster than the other. It really depends what apps you use, and even within a certain app, the results can varry rather widely with different workloads. have a look <A HREF="http://www.xbitlabs.com/articles/cpu/print/athlon64-3400.html" target="_new"> here </A>
In Cinema4D, you'll notice the P4 taking a comfy lead in raystracing, but falls behind on all the other tests. Similar results in Autocad where P4 lead in one test, fall behind in others.. so be really carefull with blanket statements like "cpu x is faster for cad/3D/whatever". truth is, they are pretty damn close.
IMO, the A64 gives a more even performance with little to no real weaknesses. P4 performance seems to jump up and down more often and dependent on optimized code. This shows really well when you look at non commercial (or less popular) application performance where the K8 will often lead significantly (sometimes being almost twice as fast).
Add to this the much richer feature set (64 bit support, NX bit, Cool&Quiet, less heat/noise issues), its undisputed lead in gaming performance and a slight price advantage, and I would vote for the A64, especially if he intends to keep the rig for a couple of years after which time 64 bit performance might become a real issue (especialy at 3D/CAD). Nevertheless, I'm sure he'll be glad with either, just make sure you don't spend too much of the budget on the cpu. Ammount of RAM, quality/size of the monitor, speed of the harddisks, etc, those things will likely play a much bigger role in his experience.
One last word of caution: you ask for real world experience; keep in mind precious few people own both a high end P4 and an A64, most have one or the other (or neither). I'm sure every P4 owner will love his machine just as much as the A64 owner, and both will find it very fast compared to their previous setups (especially if they where ~500 Mhz class machines!!), so expect them to recommend what they have themselves. Such feedback can be usefull for evaluating compatibility/stability/installation/.. issues but not for performance. If you ask Kanavit how his machine performs in Doom3 or POVRay he'll say it *ROCKS*, even if the same budget could have bought him an A64 that would outclass it completely.
what do you think about 3000+ newcastle, it's about 35 bucks cheaper and i really need to save him some cash.
Thinking about MSI platinum mobo for 130. Nice bundle.. and it has all the features.
hmm.. maybe ima going via chip. k8t neo fsr
46,510 , movin on up. 48k new goal. Maybe not.. <P ID="edit"><FONT SIZE=-1><EM>Edited by Johanthegnarler on 08/14/04 08:43 PM.</EM></FONT></P>
Get the MSI board, and the 3000+
I dont know what level of Graphic card you need but i would recomend a 9800Pro for a smaller budget.
WD 200GB SATA, great price on a great HD.
Now all you need is an optical drive and a case/PSU
Optical it all depends if he wants a DVD burner, a dual layer burner, or just a CD burner, or just a DVD-ROM drive.
<font color=purple> I am on an express train to hell. I hope I'm in the front row, the ride is ALWAYS better in the front. </font color=purple>
Heh. Trying to find ram is tricky. I hate buying other people new new technology. Too much reading. Ilove mushkin, but i'm not too sure on how good it is with this board. And he's only got a budget of a grand.. so i doubt we are going 200gb hd. He's in college everyone has a burner .
THG did a review of like 13 brands of RAM and like 8 Mobo's
If he is doing CAD he will need a larger HD. for an 80GB you are looking at 70bucks, for 50bucks more you can get 120GB more. The 200GB IDE Ultra ATA is the lowest cost per GB for WD.
I just built a computer for like 660bucks, no monitor, no keyboard and mouse and i have a A64 2800+, 200GB HD, CD burner, and so i think if you built what i have and even upgraded a thing or two depenidng on price drops....you can still buy a decent CRT. And a keyboard and mouse should be like 20bucks.
<font color=blue> I am on an express train to hell. I hope I'm in the front row, the ride is ALWAYS better in the front. </font color=blue>
Any suggestions on a case? I'd like one without a p/s unless it's antec, but i want to make sure his a64 will be plenty a cool.
My Antec Lanboy is awesome, but i don't know if i want him all up on my style ^^>
I'm looking at this nice black lian li case newegg has on sale. 91 dollars.
46,510 , movin on up. 48k new goal. Maybe not.. <P ID="edit"><FONT SIZE=-1><EM>Edited by Johanthegnarler on 08/14/04 09:33 PM.</EM></FONT></P>
i guess spending 92bucks for a 120GBs is better then 120 for 200. Yeah, 30bucks and 80GB more. And its just as fast because you dont use the full bandwidth of it either.
the only thing it has that is a +, is a 5yr War. where as WD has a 3yr.
Ultimatly it comes down to you, and what YOU like not what me or others like.
