I have a PC with a dual monitor setup, with both monitors connected to the PC via DVI cables. I also have a PS3 connected to one monitor using an HDMI cable.
Right now, when I turn the PS3 on, I change the input manually to the HDMI input to show the PS3. If I have both the computer and the PS3 on at the same time, and I have the monitor auto-select which input to use, it always selects the DVI input (my PC).
I'm trying to find out if it's possible to alter the input priority of this monitor so that it displays HDMI before DVI. I've searched the monitor's menus for this without any luck. Does anyone know if there's either a service menu for the monitor that would allow me to change this, or if there's any kind of program I can use to alter this?
P.S. I did think of one sort of solution for this: I could connect my computer to the monitor via HDMI cable, then buy a cheap HDMI to DVI converter off of ebay to connect the PS3 to the DVI input. Then, the PS3 would have input priority. However, I don't like the way the computer handles the HDMI connection during startup, so I'd like to find another solution if possible.
Thank you for your help.
