Why does my subwoofer over heat and shut down
my polk 110 subwoofer works for about 10 minutes then stops producing volume, the back panel is extremely hot.
1 answer Last reply
More about subwoofer heat shut down
  1. I have heard of problems with the amps in some of the Polk sub woofers or it's over heating if the vents are blocked or clogged.
Heat Shutdown Audio
