...put them together? Can anyone recommend a good builder's guide? All the ones Ive found are 2-3 years old. I dont want to make a mistake and possibly damage my expensive components. As youve probably guessed, this is my first build and I have little idea what Im doing.
Thanks.
Remember it is best to assemble parts on a shag carpet, keeps static away.
And large pliers are necesary, along with electric drill driver. And remember to torque up those screws, to reduce vibrations.
Try everything...
Do not be afraid of failure, for this is how we learn and grow...
Live life to the fullest...
Do not regret what you have not yet done!!!
My suggestion would be to turn your current computer off and start taking it apart and putting it back together. You can probably afford to make that mistake. Then go ahead and work on the new one.
A trick that I like. You attach the power cord to the case, but leave the power switch off. This grounds the case so it helps prevent static buildup. Not a good idea in a lightning storm though.
Be sure to unplug power supply when connecting power cables on mobo, cards and periphs. Can cause a spike.
Try everything...
