Ok Guys, from my previous post i said i have a 1.6a o/c at 2.1 and i was getting like 30 fps on counterstrike source.. I took the advice from u guys and added another 512 megs.. So i had 512 megs pc 2100 ram, and took it out and bought dual 512 megs from mushkin, the black line level 2 ram. I also bought a gef 6800 oc card. So i went from the gef ti 4200 to the gef 6800 and changed the ram from 512 megs pc2100 to 1 gig pc2700 ram. Im running at 2.1 and the timing is 2 2 2 7.
I still get 30-40 fps in counterstrike source. Just a little difference but not much at all. Im really upset, i thought the extra ram and this super graphics card would do the trick, it hasnt.. Im thinking of buying this pc.
http://www.cyberpowersystem.com/highendsystem/inf8000.asp?v=d but with an agp slot so i can keep my gef 6800 . im thinking of doing the 3.0 ghz pc.. Will this do the trick?
I really want to save the pc i have now. 2.1 ghz and a gef 6800 oc card i figured i should be getting 70 fps at least.. The fps is at 70 when there are maybe 2 players on the screen but once the shooting starts it goes as low as 20fps. ANy other ideas before i take this big step? I have the 1170 agp drivers from SIS, fast rights are off. I even o/c my pc to 2.4 ghc but i dont want to fry anything so i leave it at 2.1. I even reinstalled win xp. Still the same.. any other ideas? is a 3.0 ghz pc with 1mgh cache good enough? or should i just get the regular 3.0 ghz pc with 512 cache.. I dont want to spend to much money but this company puts it all together for me. Can someone check out the pc i mentioned and tell me what u think? here is the link again. http://www.cyberpowersystem.com/highendsystem/inf8000.asp?v=d
but will the regular 3.0 or 3.4 ghz pc with the 800 fsb 512k cache be enough?? thanks guys.. here is my specs now.
asus p4s533 1.6a cpu o/c at 2.1 ghz
gef 6800
1 gig mushkin level 2 black timed at 2 2 2 7.. also i have a 350 watt powersupply. the gef needs only a 300 watt.
anyone know if there are any jumpers on the mb i need to change? i did go from pc2100 to pc 2700 ram. thanks.
thanks a lot.
gef 6800
thanks a lot.
