Archived from groups: microsoft.public.broadbandnet.hardware (
More info?)
So long as that port is connected to the other MN-500.
Paul wrote:
> Joker-
> Thanks for the reply! This may be a stupid question, but
> my new house is apparently "wired" with ethernet ports in
> various rooms. Would I follow a similar setup? Could I
> just plug another MN-500 box into the wall?
> Thanks!
> Paul
>>-----Original Message-----
>>Broadband modem --> WAN port of MN-100, MN-500, or MN-700
> #1
>>MN-100, MN-500, or MN-700 #1 LAN port #2 --> WAN port of
> MN-100, MN-500,
>>or MN-700 #2
>>MN-100, MN-500, or MN-700 #1 LAN port #3 --> WAN port of
> MN-100, MN-500,
>>or MN-700 #3 (if available)
>>Make sure all MN-100s & MN-500s are running the latest
> firmware 1.11.017
>>Make sure all MN-700s are running the latest firmware
> 2.01.02.0590
>>Now lets look at the setup of each MN-100, MN-500, or MN-
> 700:
>>router mode
>>LAN IP address at default of 192.168.2.1
>>some SSID (if wireless)
>>some WEP key or WPA key if MN-700 (if wireless)
>>channel 6 (if wireless)
>>MN-100, MN-500, or MN-700 #2
>>bridge mode
>>LAN IP address at 192.168.2.42, outside of default DHCP
> range
>>same SSID (if wireless)
>>same WEP key or WPA key if MN-700 (if wireless)
>>channel 1 (if wireless)
>>MN-100, MN-500, or MN-700 #3 (if available)
>>bridge mode
>>LAN IP address at 192.168.2.43, outside of default DHCP
> range
>>channel 11 (if wireless)
>>If you keep the SSID and WEP key or WPA key (if using the
> MN-700) the
>>same for all base stations, people will be able to move
> between
>>locations and get a connection.
>>If you are using WEP on some but WPA on other wireless
> routers you will
>>have to reconfigure the wireless settings as you switch
> between wireless
>>networks.
>>You need to select non-overlapping channels for the base
> stations to
>>prevent interference.
>>Non-overlapping channels have at least 5 channels between
> them as 1, 6,
>>& 11 do.
>>Channels 1, 6, & 11 are the three non-overlapping
> channels.
>>There are more combinations if you only need two channels.
>>Paul wrote:
>>>I currently have an MN-500 network that works great in
> my
>>>2 bedroom apartment, but I am soon moving into a much
>>>larger house with three floors.
>>>Assuming that the single base station won't be
> sufficient
>>>to provide high-throughput access throughout the house
>>>(which I would presume is very likely), can someone
> tell
>>>me what my options are for extending the range of my
>>>network? What hardware do I need to purchase?
>>>Thanks!
>>>Paul
