Problem with WW single drop target
G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
The problem is the drop target is either non functioning or is
intermittent. I have disconnected everything on the same line and it
still has the problem but in switch test this opto triggers everytime.
Any suggestions.
Thanks
Brad
G
Guest
Guest
Just replace the U-shaped opto.
I had the same problem - it worked well in test but not during the
game.
Replace the opto and it worked fine.
I guess during test the game does a better effort of reading the status
of an opto than during the game, so if it starts to die you get these
problems.
Aeneas.
G
Guest
Guest
> game.
> problems.
> Aeneas.
Finally got around to changing this and that was it.
Thanks
