Hello, my USB won't connect on my computer since I tried to put it on my xbox360. But when I do, windows does the sound. Tried to desinstall/reinstall, without success.
If you notice when you have a USB flash drive connected to your computer and you want to unplug it you go to the task bar and select safely remove device and when it says it's ok you remove it. Does the X-Box have a similar choice ?
