G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
After replacing the batteries in my TSPP, I'm wondering if anybody
bothers to replace the nylon wire tie that straps the battery holder
down to the board. It's a pretty stupid design. No easy way to
replace the wire tie without removing the board, since it threads
through two small holes in the PCB. The battery holder appears to be
held only by two through hole terminals, and I'm worried that vibration
will fatigue them.
Thoughts?
h_h
will fatigue them.
Thoughts?
h_h
