Solved
Condenser microphones phantom power vs preamp
Hello,do the Xenyx mic preamps on a Behringer Xenyx 1204USB mixer send the phantom power out the xlr inputs to a condenser mic ? or does the phantom power just run the pre amp? sorry if it is a dumb question but i can't figure it out from reading the specs or description
3 answers Last reply Best Answer
More about condenser microphones phantom power preamp
  1. Best answer
    The mixer provides phantom power to the microphone, from the XLR connector. The phantom power runs the mic, not the preamp.
    thank you guru ,..... gee you, are you ?
  3. Best answer selected by busker.
Power Audio
